Ga door naar hoofdinhoud
A corded, electric, 5 amp spiral saw power tool with a two speed motor by Rotozip. The device comes with a variety of drill bits, sanding and polishing wheels, and a carrying case.
4 Vragen Bekijk alle
Why is my blade attachment not spinning?
My saw didn't have any problems before I changed the blade, but now the attachment won't spin at all. I don't know what I could've done to break it, help!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Try taking the blade off and attaching it again. If it still doesn't work you might have a faulty attachment. Also, do you at least hear the motor spinning inside? If not, than it might be a more serious problem and you might need to replace the motor itself. Be sure to check out the troubleshooting page for the RotoZip rebel first. Here's the link
RotoZip Rebel REB01 Type 2 Troubleshooting
Was dit antwoord nuttig?
You did release the lock I assume after changing the tool bit?
Voeg je antwoord toe
Lauren Russell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 1,387
