Ga door naar hoofdinhoud
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
20 Vragen Bekijk alle
My Kenmore 110 Series washing machine won't start
My Kenmore model 110 series washing machine will not start. When i power it on and try to start it the machine makes a loud buzzing sound and doesn't start up.
Thank you.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
arcadiafilm, Motor does not start, but makes a buzzing noise then it may be faulty. To check motor, remove the drive/pump belts and try to start the motor. If direct drive model, disengage the pump/direct drive coupling at transmission, if the motor starts, problem is with the transmission or pump and which can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced. Some times the pumps will accumulate debri or piece of small clothing wrapping around pumps propeller stopping motor from spinning. If you do not feel comfortable working on machine have a good repair Tech. have a look, diagnose and estimate repair. Check the attached links,instruction and guides, Good luck.
http://www.partselect.com/Repair/Washer/...
Kenmore 110 Series Washing Machine Drive Belt Replacement
Kenmore 110 Series Washing Machine Water Pump Replacement
Kenmore 110 Series Washing Machine Water Pump Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
15 - 30 minutes
Kenmore 110 Series Washing Machine Drive Belt Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
15 - 30 minutes
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I just replaced the lid lock switch on my Kenmore 110 washing and it won’t start now. It is like there is no power going to it. I have checked the and there is power going to where I plug it in, so that isn’t the problem. Can you give me another idea as to why it wouldn’t turn on?
door
Voeg je antwoord toe
arcadiafilm zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,748
