Ga door naar hoofdinhoud
Het iHome iP1 audiosysteem, ook wel bekend als de iHome iP1 Studio Series, werd in juli 2009 uitgebracht door SDI Technologies.
Why does my left speaker sound muffled?
My iHome was working just a few hours ago but now when i play music, the left speaker doesn't seem to be playing at full volume. It also sounds muffled and I am not sure why.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Your woofer could be obstructed by something. Take the protective grill off of the front to make sure nothing is touching the driver. Also, check the hole on the back of the speaker casing to make sure there is no debris in there.
If nothing is obstructing the speaker, check to make sure the speaker is correctly connected to the motherboard. To access the motherboard, simply unscrew the large plastic cover on the bottom of the iHome system and remove the cover. Once the cover is off, make sure all the wires are connected correctly to the motherboard.
If everything is connected correctly, and nothing is obstructing the speaker, the speaker may be the problem. Visit the iHome iP1’s device page to view the guide on how to replace the woofers.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Wen Sullivan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,707
