Ga door naar hoofdinhoud
Dit is een stofzuiger van het merk Dyson. De stofzuiger werkt op een accu en is voorzien van een krachtige motor en een zakloos stofreservoir.
Why is vacuum overheated
My stops working for a once a while them starts again almost like it overheating
Is dit een goede vraag?
2 opmerkingen
Charge battery over night, turn on to vacuum , runs maybe 30 seconds , shuts off , put on charger for approx, 5 minutes ,works great ????
door
The best thing to check is isolating a blockage or airflow hinderance.
Take all the parts of. Including the full bin off the motor and the back filter from the motor. Now all you have is the motor and handle, run the motor. If it doesn’t shut off then it’s a blockage. If it shuts off it’s probably a motor fault.
Mine worked after a replacement back filter, you can get them on Amazon cheap. But make sure it also has good airflow. I also cleaned out the small hole in the bin that sucks in dust, this often gets blocked. Then the base roller thing often gets clogged too.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
dougcarrol, Dyson v6 shuts off like it may be over heating, could be Dysons thermal cut out. Found this info. at the Dyson link below, Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. May happen because the filters need cleaned/washing, machine could be plugged/blocked, floor brush roller seized from debri/hair wrapped around brush. Unplug, check filters, check for blockages, clean brush so it spins easy. Check the links below for more info. and instruction. Also note Dysons contact link, as I was informed they can also answer any questions you may have on their products. Good luck.
https://www.dyson.co.uk/support/dc24/dc2...
https://www.youtube.com/watch?v=rSNnOhR6...
https://www.dyson.com/contact.aspx
Was dit antwoord nuttig?
Score 3
I found the already posted answer helpful but felt like a little room for more information on the complete troubleshooting, hope it helps.
Reasons for Dyson Overheating & Cutting out:
  1. Dirty Filters: Reduced airflow due to dust and debris can lead to overheating.
  2. Clogged Cyclone Assembly: Excessive dust hampers airflow, straining the motor.
  3. Clogged Brush Bar: Jammed rollers or a malfunctioning motor can cause overheating.
  4. Faulty Interiors: Worn-out components may contribute to the issue.
Solutions to Fix Overheating:
  1. Clean Dust Bag: Regularly replace the dust bag to prevent blockages and overheating.
  2. Check Air Filter: Clean or replace the air filter to maintain optimal airflow.
  3. Inspect Belt: Ensure the belt is in good condition to prevent motor strain.
  4. Address Electrical Problems: Check for damaged cords and internal components, seeking professional help if needed.
  5. Let Dyson Cool Off: Restart the vacuum only after it has cooled down to avoid internal damage.
  6. Reset Thermal Fuse: Disconnect power and allow the vacuum to cool for an hour for the thermal fuse to reset.
I have added the source as a hyperlink in the first heading, I actually tried briefing the answer concisely here and cutting the fluff. Well, I'm glad it helped me fix mine by resetting the thermal fuse.
Voeg je antwoord toe
dougcarrolwilliams zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 200
Altijd: 46,576
