Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Eerste generatie van de SLK, ook bekend als het R170-platform.
How to add engine coolant
where to add coolant
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Keith, open the hood of your vehicle locate the coolant reservoir (link below will show picture of reservoir) normally mounted on rad cradle or inner fender well, look at markings on translucent area of reservoir to determine level of coolant. If coolant shows low or empty, when engine is cool remove reservoir cap and add specified coolant till at a acceptable level. If you had to add a lot of coolant to get it to correct level, you may have a leak, in this case it may be wise to have a good technician have a look and pressure test cooling system, diagnose and estimate repair if required. Check the attached links,instruction and guide, Good luck.
http://www.ebay.com/itm/01-02-03-04-MERC...
http://www.slkworld.com/slk-r170-class-d...
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
Note: I would suggest checking the coolant container before adding, to see if the MB coolant is premixed (diluted); if it's not premixed, add a 50-50 mix of concentrated coolant and distilled water.
door Deel
I replaced a coolant hose and need to add coolant but don't know where to add it at
door Deel
Btw does anyone know what coolant is the correct one for the 4 cylinders ? Just knowing color would be good.
I have a 230Kompressor. Cant see the stuff without needing to put in a dipstick etc.
door Deel
Voeg je antwoord toe
Keith Vines zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 67
Altijd: 16,618
