Ga door naar hoofdinhoud
Repair guides and support for weed whackers, also known as string trimmers, weed eaters, edge trimmers or line trimmers.
87 Vragen Bekijk alle
Why does my Echo SRM-225 gas trimmer stall or bog down?
My ECHO SRM-225 starts on cold setting but dies out soon after, sometimes one to three minutes, sometimes just a few seconds. Throttling always makes it bog down and stop. I recently replaced fuel line and filter (Echo 90097 kit) and still, no better. I have been using TRuFuel 50:1 with no problems for months until now. I checked the plug, not dirty at all. I just checked the spark arrestor screen, and it was clean. The one thing I do notice is an accumulation of grease/oil near the exhaust.
Any suggestions would be appreciated.
Thanks in advance
Miguel
Is dit een goede vraag?
Score 5
8 opmerkingen
I had the same issue, oily exhaust port and bog down/stall on acceleration. I disassembled carb.. cleaned, (I thought). Cleaned exhaust port. Still a no go. Then I removed the gas filter, same problem. Finally I put the intake hose in my mouth and blew and sucked on it. I left fuel filter off. Now she is running without bogging down and idling okay. If I removed the gas filter and blew and sucked on the line first, I would not have to go through disassemling the muffler and carburetor. I sprayed the jets but the clog must have been in the fuel line. I don't know why my exhaust port was so oily and I thought too much fuel was getting through initially, but that was not the case. I did not make any adjustments to the carburetor. My woeful tale turned to glee and relief, Thanks for your time.
Billy. I own my own lawn service. Thanks for your guidance.
door
It was the cap for me and wasn't getting the full power and oil leaked so I replaced the carb for $15 Amazon and cap, runs like new.
door
Don't use gasoline containing ethanol, it plugs carburetor jets.
door
Is it normal for a Echo weedeater to shut off when it gets to half tank?
door
I have cleaned my carb, replaced the spark plug, air filter, all the hoses and fuel filter and am using no ethanol gas mixed 50:1. Starts on first pull idles great, but when I throttle it, it bogs down. I think it's time to buy something else.
door
3 commentaren meer tonen
Voeg een opmerking toe
7 Antwoorden
Gekozen oplossing
elgitano, 4 common things are gas cap venting plugged(loosen cap to see if it runs better). 2nd spark arrester screen plugged, remove and clean the muffler and screen and check exhaust port for carbon accumulation, scrape port clean while holding with port position down or use vacuum so debri will not fall in cylinder when cleaning(carbon debri could harm cylinder walls and rings). 3rd is carburetor out of adjustment,(you may have to adjust the carburetor high or low jet screws) to achieve normal running condition.
4th If none of the above seem to help chances are the diaphragms in carb. need replaced/ rebuild and clean carb. Check the attached links,instruction and guides, Good luck.
https://www.youtube.com/watch?v=U0LJ3gX2...
https://www.youtube.com/watch?v=0wcmc83y...
https://www.youtube.com/watch?v=cGlJB0on...
https://www.youtube.com/watch?v=KOqTguWw...
Was dit antwoord nuttig?
Score 9
15 opmerkingen:
I appreciate the quick reply L Pfaff. I've actually watched all 4 of these videos today, but will review them to see if I may have missed something.
I failed to mention that I had previously pulled the carburetor apart, but it looked quite clean and in order (i did not replace diaphragms though).
Then, I replaced the fuel lines and gas filter, including the primer bulb. I checked the spark arrestor screen (it was clean) though I did not invert to vaccuum out any possible debris. I had also tried to run it with the fuel cap loosened with no luck.
I have one question concerning the high and low jets- honestly, I don't know where they are on this SRM-225.
I will clean/scrape/vaccuum exhaust port and check diaphragms more closely, and if I can find adjustment screws for jets, I will try them as well.
Definitely very helpful and I appreciate the detailed answers, L Pfaff.
I will be back on to let you know how things are progressing and mention the solution.
Thanks again!
door
elgitano, did you try a new spark plug in case it is fouled,
Echo Zama Carburetor hidden Hi jet screw, link below.
https://www.youtube.com/watch?v=mmbZ5Arp...
door
I did try a new one with no success, but this last link you sent gives me hope!
I will try this out tomorrow morning.
Thanks again!
door
Carburetors on these things are notoriously finicky. It's unlikely the diaphragm needs to be replaced, but it is likely that one of the tiny little passages is clogged. Use a can of spray carb cleaner to make sure all the passages are clean. Inside the main metal part of the carb you'll see a number of tiny holes on the sides, make sure all of them are unclogged (liquid should come out of them when you spray into a corresponding hole in the carb). I know this sounds a bit vague, but just take the carb completely apart and spray the cleaner into every hole / passage. Sometimes this needs to be repeated several times to get it completely cleaned out. Just because it looks clean, doesn't mean it is. These passages are so incredibly small, it's impossible to tell by looking if they are clean or not. Let me know if this doesn't make sense.
door
Makes perfect sense. I've done this many times with the mower carb but had never really piddled with gas trimmer engines before. I had a corded trimmer for so long, and this ECHO is a relatively recent addition.
All in all, in my limited garden power tools experience, I like the ECHO trimmer despite the current troubles.
I will definitely do what you have detailed, including the removal and cleaning of the hidden jet.
Your answers are anything but vague. I love detailed answers.
Thanks yet again.
door
10 commentaren meer tonen
Het nuttigste antwoord
It's 110% the hidden fuel mixture screw. I've messed with a million and 1 of these echo 225’s and it's just out of set. There is a hidden fuel mixture screw right below the primer bulb that usually needs loosened and that almost always fixes the bog down problem with those particular weed eaters…
Score 11
9 opmerkingen:
This fixed my issue on a pas 225 that had light use last season was put up without fuel in it each time nothing wrong with the carb nothing blocking the screen on the exhaust
door
You are a life saver! I had to grind down a screwdriver to fit in to adjust the carburetor turned it to the right and has no bogging down and lots of power. Thank you so much!
door
Worked like a charm, though it took me a minute to determine the type of screwdriver needed. Thank you!
Most of the above comments were made by folks who had never really experienced this problem and were offering, good and heartfelt answers, but they were wrong answers. One twist of the screw to the rigjt and Vroooom! Working. You nailed it buddy!
door
What kind of screwdriver??
door
Some said "turned it right", to loosen, turn it left. I loosened the screw under the bulb primer and it ran better but still bogged. I took the screw all the way out and it ran like new. I was able to get it up to full throttle, first time in many seasons. Unless there is a good reason to put the screw in, I'm going to try running with it all the way out.
door
4 commentaren meer tonen
My lawn mower was doing this. I bought new gas and mixed in some Seafoam gas treatment. I drained the tank and put in the new gas / Seafoam mix. Mower immediately started running like new and it still is running like new a year later.
https://seafoamsales.com/small-engines/
Score 1
1 Opmerking:
This spring I bought some new gas and added 10 yr old Castrol Super Oil. The Echo would only idle and would die with any throttle. Dumped it all. Got new gas, added Lucas semi synthetic 2 cycle oil. Bought but did not use Seafoam. The Echo is now running smoothly. It would seem that the old Castrol 2 Stroke oil was the culprit.
door
I was able to fix mine by pulling the vent line up (the 1 with the tiny white filter coming out of the gas tank) to where it sets above the gas level when the tank is full. It was sitting too deep in the tank to where it was submerged in the gas and unable to pull air causing the tank to vapor lock and the motor to stall out. It would run upside down because it created an air bubble in the gas tank just above the vent line when flipped over or turned at an angle.
Score 1
pull and clean your spark plug with some carb cleaner and a wire brush. had the exact same problem: idling like crap then when I pulled accelerator lever it would conk out almost every time. pulled the spark plug and was black. cleaned it, popped it in and voila! lots of smoke for a bit, but running like a champ.
hope this helps
-Art
1 Opmerking:
Remove the exaust and check if there is carbon built my pas-266 had that problem.
door
Question on the fuel mixture screw. Seems there is a covering, maybe rubber, no over the screw. What is that and how do I get it off to get access to the screw. It's so tiny and hard to see.
2 opmerkingen:
Good question but no one answered. I'm re-asking this question in the hopes of getting an answer.
door
Take a small drill bit and heat it to red hot at the tip. Insert that and just barely start to drill. It should catch, and you can pull the piece out giving you access to the adjustment screw.
door
Exceptional folk come along only every so often, gifted in figuring out and solving arcane and nee' everyday problems that once a solution is offered seems simple. Lpfaff is one and I, for one, am grateful for it. Shalom
Voeg je antwoord toe
elgitano zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 105
Afgelopen 7 dagen: 829
Afgelopen 30 dagen: 3,039
Altijd: 191,583
