Ga door naar hoofdinhoud
De TDK Life on Record A33 is een weerbestendige Bluetooth-luidspreker. Deze werd in 2012 uitgebracht en is inmiddels niet meer leverbaar.
turn off (stop) automatically when AUX playing
I connect a33 with my tv, with headset output.
but a33 automatically shut down (like power saving) in 30 minute.
how i can turn of that feature or fix?
ps. I attempt toggle battery button and aux/bluetooth, power on/off...etc
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
According to the User Manual the player has an Auto Power OFF feature, as you know, that turns the speaker off after 20 minutes (that's what it says) if there is no audio signal or if it is not charging a USB device.
Try connecting the supplied AC adapter to the DC in jack. Because it is being charged (or the state of the battery charge is at least being maintained) it should stay on.
If it doesn't then plug your phone (in charge only mode) into the USB charge port and then see if the player stays on. If it does then it means that it must 'sense' that there is a current flow in the USB port and will stay on. If this is the case you may as well keep it simple and leave any device that can be charged via USB in there. This will ensure at least that they are always charged and that the player stays on.
Here is a link to the User Guide.
http://downloads.imationsupport.com/lor/...
Was dit antwoord nuttig?
Score 3
1 Opmerking:
before all, thanks your answer :) you developer of TDK :) ???
and sorry to my short English ㅇ.ㅇ
I try ALL of cases like toggling switch, connecting(?) line like under list and maintain in 30 minute, but any of case do not fix the problem.
1. factory reset
2. DC connect / disconnect
3. USB connect / disconnect
4. Battery switch toggle
5...
and, find only one solution.
1) 3.5pi in TV disconnect -> connect (3.5pi in speaker disconn/conn, do not solve this problem)
I think if speaker is turned off->on(maintain connecting), do not recognize sound even playing.
this speaker is famous in korea, so I find people like me has same problem. I think programatic bug.
thanks! you are angel
door
Voeg je antwoord toe
myleaf0410 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 32
Altijd: 7,822
