Ga door naar hoofdinhoud
Repair guides and support for the first generation Grand Cherokee ZJ, an upscale mid-size SUV built by Chrysler's Jeep division.
47 Vragen Bekijk alle
Were is my camshaft sensor at.
Were is the camshaft sensors and how do I get to it.
Is dit een goede vraag?
Score 2
1 Opmerking
Unfortunately, this is NOT accurate for a 1998 Jeep Cherokee Sport (classic) powered by the 4.0 six cylinder engine.
door
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
@crazymomma you did not tell us the engine size for your GC. Here is some imformation from a service manual. Should make it pretty straight forward. On the 4.0 the Camshaft Position Sensor (CMP) is bolted to the top of the oil pump drive shaft assembly. The sensor and drive shaft assembly is located on the right side of the engine near the oil filter.
REMOVAL - SENSOR ONLY
* Disconnect electrical connector at CMP sensor.
* Remove 2 sensor mounting bolts.
* Remove sensor from oil pump drive.
On the 4.7L engine the Camshaft Position Sensor (CMP)is bolted to the front/top of the right cylinder head.
REMOVAL
  • It is easier to remove/install sensor from under vehicle.
  • Raise and support vehicle.
  • Disconnect electrical connector at CMP sensor.
  • Remove sensor mounting bolt.
  • Carefully pry sensor from cylinder head in a rocking action with two small screwdrivers.
  • Check condition of sensor O-ring.
INSTALLATION
  • Clean out machined hole in cylinder head.
  • Apply a small amount of engine oil to sensor O-ring.
  • Install sensor into cylinder head with as light rocking action. Do not twist sensor into position as damage to O-ring may result. CAUTION: Before tightening sensor mounting bolt, be sure sensor is completely flush to cylinder head. If sensor is not flush, damage to sensor mounting tang may result.
  • Install mounting bolt and tighten to 12 Nm (106 in. lbs.) torque.
  • Connect electrical connector to sensor.
  • Lower vehicle.
Was dit antwoord nuttig?
Score 3
What if a socket gets dropped into the hole the sensor goes in
Buy a magnetic pick up tool and cross your fingers. If extraction of successful pat yourself on the back got a cold beer I revel in the accomplishment that you managed to pull off.
I lost my keys bought a new ignition had a friend tht was scraping theirs got the doors put them on mine. But now my girl set the alarm off and couldn't get it to go off so I've been trying a few things got alarm to go off but still isn't getting fuel after a few seconds it dies bc theanti theft wont pump gas after the first turn of key
98 jeep grand cherokee
1 Opmerking:
moser1daddy, I recommend to start your own post and not put your problem under a cam shaft position sensor post if you want more people to look at your anti theft problem.
door
If it's a 93 or 94 it's inside your distributor, take off Distributor cap, mark its position, then pull the whole distributor out, the cam sensor is at the bottom
Voeg je antwoord toe
Jeanie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 237
Altijd: 14,382
