Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Vragen Bekijk alle
No sim card slot AND small triangular piece dropped out
I am in the middle of replacing the iphone 4 home button.
I the video, I am at the step where the sim card is removed.
My verizon phone doesn't have a sim card slot.
Rather than proceed with the process, I was going to put everything back until I could get better directions.
Unfortunately, when I picked up the phone, a small right triangular piece dropped out.
It has a hole in it.
I don't know where it came from.
I don't know which way to go. Can I ignore the missing sim card step or
can someone tell me where the triangular piece goes.
(there was also a small cubical rubber piece that fell out, but I think I know where that goes.
Thanks for any help
Is dit een goede vraag?
Score 1
1 Opmerking
I looked over the repair guide that you sent me and it is the correct one. I actually recognize the parts in my phone. Fortunately, I was able to figure out what the missing parts were when I reassembled, but it is a relief to know that I did it correctly. NOW, I am going to take it all apart again and try to finish my repair. Thanks.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
@skoski if this is the same phone as in your other question, you already know that you are using the wrong guide. Your phone is a CDMA phone and the guide is for the GSM phone. Step 26 of this guide is most certainly the piece you are inquiring about. It is also the proper guide for your phone
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Only the iPhone 4s (and the iPhone 4 CDMA variant) has the black triangle piece. It sits on the left side of the loudspeaker assembly.
It it used to hold the left side of the loudspeaker in place via the left screw hole. Place the plastic triangle in first then the screw on top at the screw hole.
See this link for example: https://d3nevzfk7ii3be.cloudfront.net/ig...
Score 3
2 opmerkingen:
The CDMA phone also has the triangle piece. You can see it at step 26 in iPhone 4 Verizon Home Button Replacement
door
Thanks for the info! Updated my post.
door
Did the piece that fell out look like this?
https://www.mengtor.com/ajax.php?act=buy...
Score 1
1 Opmerking:
No, the piece is made of plastic and it is a black triangle. I think it is part of the speaker assembly. The part that you showed me looks like the sim tray but verizon phones don't have sim trays at all.
door
Voeg je antwoord toe
A S Koski zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 200
