Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Broken home button / fingerpr. scanner iPhone 6 after replacement
Hi, i have replaced a new lcd screen to the front metal plate on my Iphone 6 , but unfortunately i damaged some of the small little plugs on the connector on the home button when i loosened it. So my question is , is it possible to loosen the broken connector on the home button and buy a new contact so the fingerprint scanner can function again. Someone who has such a guide to refer to ?
Is dit een goede vraag?
4 opmerkingen
Which part of the home button connector was damaged?
The one on the board?
The one along the backplate?
The tiny piece that goes from the home button?
Please answer and I can help more.
door
Hi , its the connector on the home button that secured to the connector from the back flex cabel from the metal plate.
door
ugggh....that's the worst one!
You can easily replace it, but your fingerprint scanner will no longer work :(
door
Ok, than i dont think i will try do it , thanks :-)
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Since the home button is damaged, unfortunately, the Touch ID functionality won't work anymore, even if you replace your home button. If you do replace your home button, it will still "click" to go to the home screen still!
Was dit antwoord nuttig?
Score 1
Should not be overly difficult. You need to find the righ type of connector and solder it on.
The main problem is limiting heat damage. FPC and adjoining parts may not take the heat for rework. Also if you destroy it you lose it forever.
Score 1
Voeg je antwoord toe
B Tobiassen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 95
