Ga door naar hoofdinhoud
7" multimedia-tablet van Barnes & Noble, uitgebracht in november 2011. Reparaties zijn eenvoudig en vereisen simpel wrikgereedschap en schroevendraaiers.
Nook shuts off when SD is inserted
NOOK model BNRV200. I just replaced the battery, nook turns on but when I insert the SD card it shuts down and will not power back on. I can only get it to turn back on when the SD card is removed. All functions work when SD is not inserted.
Is dit een goede vraag?
1 Opmerking:
Check the SD slot to make sure no contacts are crossed or there is nothing jammed in there that would short out the contacts when SD is inserted. Also make sure that this SD card is of the correct size for this tablet and has been formatted correctly. It may need reformatting or replacing. Also check the work you did on the replacing of the battery. Make sure nothing is bent shorting out or broken.
door
Voeg een opmerking toe
1 Antwoord
@zinny sound slike either your SD card or the SD card reader is shortenibng out when you insert the card. Try a different card, should it still shorten out open your Nook up and take a look at the card reader. Also, double check your work since this started after you repalced the battery. Make sure everything is properly connected and that nothing got bend or broke.
Was dit antwoord nuttig?
Voeg je antwoord toe
Zinny zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 280
