Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De N64, uitgebracht op 23 juni 1996 onder modelnummer NUS-001, is de eerste 64-bit spelconsole van Nintendo en bleef dat tot aan de release van de Switch (de GameCube, Wii en Wii U konden wel 64-bit floating-pointberekeningen uitvoeren, maar dit is geen echte 64-bit architectuur).
Help with Freezing Nintendo 64
Hello, I have a nintendo 64 with the ram expander and after a random time, it freezes. I tried cleaning every cartridges and the cartridge slot but it keeps freezing. ( There is still music sometimes but the image is frozen )
Can someone help me ?
Thanks !
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
Is it an officially licensed Nintendo expansion pak? Way back when there were third party expansion paks that had a knack for heating issues and freezing problems. If it is Nintendo branded, then the RAM may be going bad. Switch it out for the original jumper RAM and see if the problem persists.
Was dit antwoord nuttig?
Score 8
1 Opmerking:
Hello , It is not an official Nintendo RAM, I tried the original RAM (the black one)and i played 30 minutes without freezing. So i think the problem is solved.
Thank you !
door Deel
Hey i had the same problem, luckily i had another expansion pak and swapped it and it works fine. It might be your jumper pak or expansion pak, try switching with another one.
I have the same problem. I replaced the expansion pak by the jumper pak which came with the console. Freezes do not happen as often as with the expansion pak, but still happen every ten minutes. Any idea what I could do?
Thanks!
Voeg je antwoord toe
Alexandre zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 154
Altijd: 34,414
