Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Temperature cool down always on
I was replacing charging port on an iPhone 6 and I connected the new port and tested it before installing and when it turned on it said it needs to cool down. The phone isn't hot and this is always on and won't go away. The phone worked perfectly fine before I attached the new charging port
Any ideas
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Bad battery or bad connection of battery/board can cause this--the logic board needs to get temperature information from the battery
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
Replaced the battery and the issue is now solved
Score 2
Voeg je antwoord toe
David F zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,429
