Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
Assembly Cable #3
How do I put Cable #3 back into the socket?
Is dit een goede vraag?
Score 2
2 opmerkingen
Thanks for the responses' exactly what i needed
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
What you need to do is take the cable labled #3 with some tweezers and very carefully insert it into its outlet but make sure that the little latch is flipped up. when you get the cable in there flip down the latch and it will be locked in there. after that you can plug in #2 and then #1 and then close the device up and check to see if it works
Was dit antwoord nuttig?
Score 1
Make sure the plastic clip is pulled back and with your nail or a spudger push the cable back into the socket and flip down the black plastic securing clip.
For a pic, please see this question.
Voeg je antwoord toe
Al Winchester zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 22
Altijd: 20,498
