Wifi siginal iPhone 5c
I just had some repair done to the board and when I got the phone back the wifi only works when I am within 3 feet of my wireless router. I was wondering if you think maybe the antenna has loose connection or something?
Is dit een goede vraag?
Probably wifi antenna capable not plugged in. If I'm correct it plugs under the board at the to left like the other iPhone 5 and higher.
door Ben
I'm going off memory, but I also believe there is a small piece that goes up there as well. Its a little clip looking doohicky that is easy to misplace or not align correctly.
door Josh W
It sounds like your wifi antenna maybe loose . I would return it to whoever worked on it.
door Deleted
