Ga door naar hoofdinhoud
De HTC One X is de eerste HTC-telefoon die is uitgerust met een quad-core processor, uitgebracht in april 2012.
Power on off button broken off!
My daughter unfortunately broke the on off button off the top of her HTC ONE X and I am looking for a way or a part to fix this?
Afbeelding
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
The solution to this is fairly simple. I'll guide you through the process of taking the back housing of the HTC One X carefully without breaking anything.
What you need to do first is get the replacement power button ready. You can get these on eBay. You are probably better off buying the whole back cover black plastic housing altogether with the power button and volume button. Here's a link to it:
http://www.ebay.com.au/itm/New-Full-Hous...
Make sure you double check the model no if it is correct / corresponds to your one.
If you do decide to get the part and replace it, you can follow this guide to step 2:
HTC One X Knoppenvervanging
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Many thanks Ben I will follow the replacing of the back housing s you suggested!
door
Voeg je antwoord toe
Stephen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 36
Altijd: 2,595
