Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De BLU Vivo 5 is een Android-smartphone geproduceerd door BLU, een Amerikaans elektronicabedrijf. De 5 is geproduceerd door een samenwerking tussen BLU en Vivo Communication Technology Co. Ltd., een Chinees technologiebedrijf. De BLU Vivo 5 werd uitgebracht in februari 2016.
blu vivo 5 charging problem
Why wont my blu vivo 5 charge? I plugged it in the charger, and it takes a day to increase by 1%. And it loses charge very quickly when unplugged.
Is dit een goede vraag?
Score 4
1 Opmerking
vivo5 needs a strong charger. i use samsung fast adaptive charger that produce both 5v and 9v and 2A amperage
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Hi,
Is your phone still relatively 'new'?
Verify the purchase date on the sales receipt for the phone and if it is less than 12 months old, consult the warranty documentation that came with the phone as what you need to do to make a claim for a warranty repair or replacement.
Was dit antwoord nuttig?
Score 4
5 opmerkingen:
I got a replacement device through warranty and it has the same problem as the original
door Deel
Hi, Sounds like it's not a very good model doesn't it. Get this one replaced as well or see if you can get a different model under warranty of course!
door Deel
please change my mobile
door Deel
I had the same problem with 2 brand new Blu Vivo 5 devices, but it has turned out that the problem were in the charging cables (both brand new) and not the phones... So I just bought different charging cables on the Amazon (Type C Cable 6ft, X-EDITION Gold-Plated Durable Braided ( USB-A 2.0 to USB-C Male) Fast Charger Cord for LG G6/G5, Moto Z/Play, BLU Vivo 5 XL, Nexus 5X/6P, Samsung Galaxy S8 Plus, (Gray, Gold) 2-Pack) and ta-daaa! No more problems with that! Works like a charm! Just buy new charging cables.
door Deel
I also have the same problem. The charger cable that comes with the phone is garbage and replacing it with a higher quality one will fix the problem. Make sure you get one that is rated USB 2.0 and higher to ensure the proper charging speed. I use the Anker 6ft USB 3.0 type-C cable.
door Deel
My blu vivo xl is 1 month old.
Same issue.
Score 4
Voeg je antwoord toe
benarde123 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 20
Altijd: 9,229
