Screen brightness going dim
Hello, what would be wrong if the display seems to be going dim and having to turn the brightness higher to see darker scenes of a movie? Not sure what the problem is. Like the scene in Lord of the Rings when the squid monster is after Frodo and the others before they go into the mine, it very dim on my tv now and I don't remember it being this way before.
Update (09/05/2016)
It is LN46A550P3F or LN46A550P3FXZA, thanks.
Is dit een goede vraag?
owens what model is your TV? This could be an issue with your backlight as well as a bad panel but this will depend on your model.
door oldturkey03
Check the capcitors on your power board. It sounds like you are having backlight issues coming from the power board. Post some images of your boards so we can see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that.
door oldturkey03
