De Sony ICFC1T wekkerradio is zo gefabriceerd dat, in het geval van een stroomstoring, u de gemoedsrust heeft dat uw apparaat blijft werken, zodat u nooit een afspraak mist.
Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
3 opmerkingen:
Bob Arn just to clarify. What projector? You selected a alarm clock/radio as the device.
Hi, Try resetting the device by removing all the power from it. By that I mean unplug the device from the power outlet and also remove the CR2032 coin cell battery as well. Then press the enter/time set button for about 10 seconds to discharge any residual power in the device. Restore the AC before reinserting the coin cell battery (be careful that you insert the battery the correct way +ve side up).
You will lose the time on the clock but since it is not working properly anyway you don't have much to lose by trying the above.
door oldturkey03
The clock projects the time on the wall. I meant to say that no buttons on the clock radio respond.
door Bob Arn
door jayeff
