Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie- en probleemoplossingsinformatie voor de HP Pavilion dv6000, een laptop van HP die deel uitmaakt van de HP Pavilion-serie. Uitgebracht in april 2007.
will not power on
when pressing the power button nothing happens. The pc is receiving power.
Is dit een goede vraag?
Score 15
3 opmerkingen
please replace the cmos battery 2032 beside memory
door Deel
So simple.
Thanks
door Deel
That is the asl HP Laptop...
door Deel
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Gekozen oplossing
This is a well documented prob with this series of notebooks and if you do a search on the Internet you'll find lots and lots of unhappy and frustrated people. The problem is the motherboard, and the symptoms include loss of bootup, VERY slow bootup, WiFi stops working, etc. is simply that the MOBO board overheats and fries the video driver chip. The cooling design of this PC is inadequate.
You might try this to verify.
1. Take the battery out and unplug the charger
2. With the computer lights OFF, press and hold down the power button for 15 seconds
3. Plug the charger back in and start-up the computer
to fix the problem you will have to either reflow the graphics chip, which may or may not work. Best would be a complete reball.
Was dit antwoord nuttig?
Score 6
1 Opmerking:
Thanks bro. It did actually work for me ! 8 years later!!
door Deel
CHECK 1:
Remove power connection, remove battery, replace battery and try again. Might fix your problem by now.
IF NOT FIXED YET:
If it tries to turn on but keeps cycling in 3-10 second reboot intervals, turns on for 3 seconds then reboots and does it over and over again. 'CHECK 1' again then. 'CHECK 2'.
CHECK 2:
As you hit the power button, after having done 'CHECK 1', hit escape a couple times this should force a boot under any condition.
Score 1
I found a problem with the power button ribbon connector I put some scotch tape on the back of the ribbon cable then reinserted it and now she works!!!!!
Score 1
1 Opmerking:
i hav try all this ways but its no working dowing the same
door Deel
Are you asking about HP Pavilion dv6000 notebook?
1. Could be memory failure. Try removing memory one by one.
2. If it's not bad memory, most likely this is known GPU failure.
You can try fixing (temporarily) the GPU problem using this trick:
How to fix video problem on HP laptops
Voeg je antwoord toe
jon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 57
Altijd: 62,621
