Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Unable to unscrew 1.2mm and 1.3mm Philips #000 screw.
I have the Philips #000 screwdriver from iFixit.
However, I seem to only be able to unscrew the 1.7mm screws. No luck with the smaller 1.2mm and 1.3mm screws. I am currently at this step.
Is this the expected scenario ?
Thanks in advance :)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Have you tried a little bigger driver? I normally use a 00 driver on iPhones.
Was dit antwoord nuttig?
Score 3
5 opmerkingen:
Dang, I do not own a #00 driver. Will try to obtain one and see if it works.
door
Thanks for the info, I've been using #0 Phillips head on iPhones which is probably not optimal.
door
I got the screws out, used a screwdriver that I borrowed from a friend. Kinda disappointing that the ifixit screwdriver does not work..
door
Yeah sometimes I have to use the german phillips head screw driver that pretty much never gets worn out and works for philips head phone screws that are hard to take out.
door
i am having the same problem. Which screw driver did you get from your friend?
door
Voeg je antwoord toe
Daylen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 2,598
