Ga door naar hoofdinhoud
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Vragen Bekijk alle
Pulsing blue light and black screen are keeping it from turning on
My phone fell. The screen is not cracked however the screen is black and the blue light dims in and out. The phone charges, as indicated by the red light when plugged in. Is there any way to get it to turn on?
Is dit een goede vraag?
Score 4
3 opmerkingen:
Plug it into your computer and see if the computer recognizes it. If it does, its just a display issue. Follow the guide to remove the screen and make sure the LCD connector is seated properly. If it is, you just need a new display.
door
I plugged the device into a computer (via the charger) but the computer does not recognize, or say that the phone is in.
door
Hey did you get it fixed? What was the problem?Same thing happened to me yesterday and i am confused.
door
Voeg een opmerking toe
2 Antwoorden
Was dit antwoord nuttig?
1 Opmerking:
same problem here, how did you fix it ??
door
You would try a soft reset press volume down and power button together for a few seconds to see if it boots up failing that u would try a new screen
Heres a handy dandy guide on replacing the screen
Samsung Galaxy S6 Vervanging van het scherm
Voeg je antwoord toe
Stacy Walton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 44
Altijd: 9,902
