Ga door naar hoofdinhoud
Why is my windows not loading up?
turned on computer. screen was blue background. screen appeared to be zoomed in. can not get windows to load up. can not see none of my icons, bar at bottom of screen, interent icon , nothing but a big blue zoomed in screen.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@riceclara30 you should explain to us why you think that the blue screen was zoomed in. You also should tell us which version windows you are using and if your computer went through the regular start-up routine. that will determine if this is an OS issue or a hard ware issue. It is possible that this is caused by a bad hard drive. Go to your BIOS and see if the crive is recognized and use a bootable CD or USB drive to see if your computer starts up normal.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
clara zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 377
