Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
20 Vragen Bekijk alle
Why doesn't my new battery work?
I went through the instructions. Getting the case off was difficult. De-soldering and re-soldering the battery went smoothly.
After re-assembly, I put the iPhone 1st gen into a dock to charge. It simply flashes the start screen (apple on black background) -- about 5 seconds on and 2 seconds off.
Perhaps the soldering wasn't perfect? Perhaps there's some other physical problem?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I have the same problem. I checked the new battery voltage and it is only .245Mv, therefore, I think it's a bad replacement battery. The old battery shows 3.79V. So, I think I will try putting the old battery back into the phone and check again.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
+ sounds like a good plan to check voltage of batteries
door
Yes, it was just a bad battery. ifixit quickly sent a replacement and the new battery worked fine.
door
just check you haven't got the solder spots too close and a shorting iphone
Voeg je antwoord toe
andrewvoelker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 769
