Ga door naar hoofdinhoud
De Bajaj Discover is een motorfietsmerk van Bajaj Auto. Momenteel zijn er vier varianten van de Discover: Discover 100 DTS-Si, Discover 125 DTS-i, Discover 125ST en Discover 150 DTS-i.
Why motorcycle 50-60 speed after started shake
how to maintain my Bajaj Discover DTS-i 100cc bike
Is dit een goede vraag?
Score 16
2 opmerkingen
how i can repair the batterie of the bajaj discover
door
After reaching 70 start shaking an and can go upto 90
door
Voeg een opmerking toe
9 Antwoorden
Gekozen oplossing
@harikall if the wobble is felt in the handle bars and goes away if you use both hands pushing somewhat against the bar, then it could be the stem bearings. Otherwise there are a few more possibilities. Could be caused by a bad tire, bad wheel bearing, and an out of balance wheel. Easiest would be to start by getting the wheel professionally balanced. As for maintaining your bike, here is the maintenance chart PMChartDiscover100.pdf
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
to check the stem bearing simply raise the front wheel off the ground and see how much movement there is in the bearing
door
The master of manuals strikes again. It never ceases to amaze me as to the manuals you can find
door
@jimfixer I'll leave you my collection when I retire ;-)
door
A motorcycle shaking at 50-60 km/h is often caused by issues with balance, alignment, or parts.
According to my motorcycle repairing experience in the past 8 years, the following are the most commonly seen reasons:
  1. Wheel Imbalance: If the wheels are not balanced properly, it can cause vibrations as the speed increases. This is often fixed with balancing weights.
  2. Tire Issues: Worn-out or unevenly worn tires can cause instability. Check for bulges, cracks, or uneven tread.
  3. Suspension Problems: Faulty or worn suspension components, such as shock absorbers, can lead to shaking.
  4. Loose or Misaligned Parts: Loose bolts, a bent rim, or misaligned wheels can disrupt smooth motion.
  5. Steering Head Bearings: Worn or loose steering bearings can make the front end shake.
Regular maintenance and inspection of these parts can help identify and resolve the issue, ensuring a smoother and safer ride.
Score 2
I've heard of front tire ply separation causing this problem. Try setting the bike up so that the front wheel can be spun and watch for a wobble in the tread. I would also look for a wobbling rim caused by a loose spoke or bent rim. A dial indicator would help with this check.
Score 1
1 Opmerking:
By the way , whats a 5 stroke?
door
Lean petrol
Bad engine mount
Air filter blocked
Engin riper smoking
Update (11/27/25)
Engin repear at bike shmoking
Bike start nahi ho rahi hai
Starting problems
Speed up power
If your car shakes between 50 and 60, it could be a number of things, such as wheel balance, tire wear, loose steering bearings, or even engine mounts. First, I would check the tires and the alignment of the wheels. To keep your bike in good shape, make sure to change the oil, adjust the chain, check the air filter, spark plug, and tire pressure. These simple things can make a big difference.
Voeg je antwoord toe
vikas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 148
Altijd: 7,306
