Maximum CPU for this laptop?
Does anyone know the fastest cpu I can put in this laptop and if it supports quad core?
Is dit een goede vraag?
The Inspiron 1545 can only accept dual-core Core 2 Duo or Core 2 Extreme chips. A Core i3, of any generation, is a no-go.
The good news is that it can take any Core 2 chip, which means you can install a 3.06 GHz T9900 or X9100 and it will work fine. A T9800 (2.93 GHz) will give it about a 40% performance boost as an example.
Was dit antwoord nuttig?
Hi, I have a Dell Inspiron 1545.
I have found a Quad Core Socket P CPU on the internet would you say it is compatible.
My current Processor Socket is Socket P.
I have a dell inspiron 1525, 4gb ram, win7 ultimate, and just upgraded my cpu to a x9100s p socket now its not booting
actually it will work you just need to try booting a LOT a person did this look it up
can i use i3 in my laptop
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 31
Altijd: 10,700
7 opmerkingen
T9900 is compatible with Dell Inspiron 1545.
I only know this because i have performed the upgrade on this laptop.
door Omar Hussain Deel
Hi Omar
I bought a T9900 on eBay, and it doesn't seem to work in my Inspiron 1545. I'm running Win10 Pro from an SSD and have 4GB RAM. From many forums I believe this processor should work. I've switched back to the T4500 and it works. I've swapped back and forth a number of times now, and all the machine will do with the T9900 installed is briefly flash the power light on the front when I press the power button. I don't get anything at all on the screen, no fan, nothing. Can't even get into the BIOS (which is on the latest version A14). Do you think I can safely complain that the processor I bought on eBay is faulty and ask for my money back?
BTW, I am good with practical electronic stuff. I take anti-static precautions, use MX-4 thermal paste, etc, so I don't think I've "damaged" the processor. I've recently replaced keyboards in two ASUS UX31E ultrabooks (complete dismantle and rebuild). Also just upgraded an ACER Veriton x270 from E5300 to a Core 2 Quad Q9650 sucessfully.
door Woody Deel
I have working T9800 on my 1545.. working like a charm with 8GB ram upgrade.. works fine on Arch linux & Windows 10
door Mahesh Deel
I am in the same situation. I tried a T9900 and it just flashes the light when you hit power. Is it DOA?
door Rodney Barnes Deel
Hi Rodney
I am begining to suspect that there may be more than one type of motherboard for the Inspiron 1545. I returned the T9900 processor I bought and got one from somewhere else, and it also didn't work!
door Woody Deel
2 commentaren meer tonen
