Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Vragen Bekijk alle
Can I use a iPhone4s microphone in iPhone4, cause iPhone4 mic broken
my microphone in my iphone 4 is broken but i have a spaer iphone4s, can i swap it into the iphone 4 to fix that mic
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
No. If you really wanted to replace the microphone that way you would need to manually remove the microphone from the part itself from the other phone.
You are better off buying the replacement parts as the assembly wont fit as a whole.
If people can not hear you during calls then you will need to replace the charging dock assembly.
You can get the charging port dock assembly here:
[gekoppeld product ontbreekt of is uitgeschakeld: IF182-009]
Guide to replacing the part:
iPhone 4 Dock Connector Replacement
If people can not hear you during calls on speaker phone then you will need to replace the top microphone which is usually together with the sleep / power button ribbon assembly.
You can get the part from here: [gekoppeld product ontbreekt of is uitgeschakeld: IF182-015]
Replacement guide for part: iPhone 4 Power & Sensor Cable Replacement
iPhone 4 Dock Connector Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
45 minutes - 1 hour
iPhone 4 Power & Sensor Cable Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
1 - 2 hours
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
chrismckjune27 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 65
