Can I use a iPhone4s microphone in iPhone4, cause iPhone4 mic broken
my microphone in my iphone 4 is broken but i have a spaer iphone4s, can i swap it into the iphone 4 to fix that mic
Is dit een goede vraag?
No. If you really wanted to replace the microphone that way you would need to manually remove the microphone from the part itself from the other phone.
You are better off buying the replacement parts as the assembly wont fit as a whole.
If people can not hear you during calls then you will need to replace the charging dock assembly.
You can get the charging port dock assembly here:
[gekoppeld product ontbreekt of is uitgeschakeld: IF182-009]
Guide to replacing the part:
iPhone 4 Dock Connector Replacement
If people can not hear you during calls on speaker phone then you will need to replace the top microphone which is usually together with the sleep / power button ribbon assembly.
You can get the part from here: [gekoppeld product ontbreekt of is uitgeschakeld: IF182-015]
Replacement guide for part: iPhone 4 Power & Sensor Cable Replacement
Handleiding
Moeilijkheid:
Moeilijk
45 minutes - 1 hour
Handleiding
Moeilijkheid:
Moeilijk
1 - 2 hours
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 65
