Ga door naar hoofdinhoud
Een bijgewerkte editie van de Samsung Galaxy S II die in 2013 werd uitgebracht, herkenbaar aan het modelnummer GT-I9105/P.
How can I fix my screen?
I droped my phone, actually it's not the first time but it was a hard one, and when i check it there was a black spot on the screen, i knew then that it's broken.
But after a few minutes the spot covered all the screen; though i still can hear the lock screen or when i turn it on so it's still working.
i think i need to change the screen or something like that but i don't know how ?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Yes you can replace the screen but the cost of replacement would probably be more than the phone is worth I see on ebay the going rate is 125 for a replacement and you will need a complete replacement LCD digitizer and glass complete .
http://www.ebay.ca/sch/i.html?_odkw=Sams...
this is a tear down video for your phone
https://www.youtube.com/watch?v=pDkvz9fU...
Everything can be fixed but not everything should be . If you have important data on the phone even with a broken screen you should be able to connect and retrieve the info unless your phone is password locked
Hope this helps
Was dit antwoord nuttig?
Score 3
1 Opmerking:
thank you so much I really appreciate it.
door
Voeg je antwoord toe
simo5991 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 30
Altijd: 365
