Ga door naar hoofdinhoud
Apparaat- en reparatie-informatie voor de 60" led-hd-tv van Samsung, uitgebracht in 2013, modelnummer UN60FH6003FXZA.
Back light dark on top
Dark the top is black
Is dit een goede vraag?
Score 2
6 opmerkingen
@duba is it just darker or is it black? do you still see things on that part of the screen?
door
I have the same problem, my screen is dark in the top.
door
I have a similar problem but I have no image or sound it just blinks now on and off and the top of the tv is darker then the bottom I replaced the power board and the main board and still no fix need any tips!
door
I have the same problem. it started gradually getting worse now to the point the top is virtually un-viewable with the darkest at the top fading back to normal at the bottom. there is three cards in the back, has to be one of them i would think.
door
@georgesl not necessarily. Could be the LED strip that makes up your backlight. Repairable by disassembling the panel itself and hopefully getting an LED replacement
door
1 commentaar meer tonen
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@dube @lintaum this is most likely caused by a failed backlight. Could be the power board, the LCD or the inverter circuitry. This is a vague answer due to the fact that we do not have all the information.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Portia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 4,643
