Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een babyfoon gemaakt door Infant Optics, Inc. De DXR-8 beschikt over een 3,5" scherm, een Temperatuursensor, nachtzicht en een verwisselbaar lenssysteem.
Power button on monitor stuck
The power button on the infant optics DXR-8 is stuck. Is there a way to fix this so we do not have to buy a new one?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Just fixed mine today because ours was stuck as well and the slightest tap to the button would turn it on or off.
What I did was:
1. Follow the dis-assembly guide on this site. I used a small pocket knife to separate the adhesive front plate.
2. Take apart a ball point pen that has a spring in it.
3. Cut a quarter of the spring off.
4. Compress the spring and place it so the less coiled end goes around the digital push button switch nub on the main board. The spring end *should* be around the nub not really pressing on it.
5. Place the plastic button on top of the spring. Might take a little finagling to get it to stay and be center.
6. Reassemble!
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
We tried this and it worked. Thanks for providing!
door Deel
Genius, worked like a charm. Thank you!
door Deel
Does anyone have any experience with the actual switch on the motherboard malfunctioning? I took it apart but the electrical switch seems to be finicky (I can't get it to function like I'd expect).
door Deel
where is the dis-assembly guide? I cannot seem to find it.
door Deel
Try removing and re-inserting the battery, that somehow fixed our issue of non-functional power button
Voeg je antwoord toe
Mitch Abby Wilson Minnix zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 66
Altijd: 21,109
