Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Vragen Bekijk alle
Vraag afgerond
What is broken if it starts apps itself?
Hi,
i have an iphone 3g, and it starts apps itself. it looks like someone is touching the screen. when you "hit" the phone it works for a while, and then it starts doing stuff itself again. when you press the screen hard in the upperright corner it works fine most of the time. i have already installed a new digitizer, but it still has the same problem.
do you know what is broken?
Regards,
Korné
Is dit een goede vraag?
Score 1
1 Opmerking:
Korne, did you get it fixed or is it still a problem?
door
Voeg een opmerking toe
3 Antwoorden
Probabily corrupt files in the firmware. Try a full restore.
Regard, Brendon
Was dit antwoord nuttig?
2 opmerkingen:
i tried, but it still doesn't work. Do you have any other ideas to solve this problem?
door
ok i tried, but it still has the same problem.
any other tips?
door
I would think the touch screen glass would be the problem. Maybe it's bent a bit, or something. Set the phone down on a sturdy surface and see if it still malfunctions. If so, try to see where it is "taping." If the "taps" are in the same spot everytime while the iPhone is still on a sturdy surface, your problem is the glass itself. Otherwise, if the "taps" are randomly placed, some other hardware is causing this. Hope this helps anyone who has this problem.
i sold the phone with the problem
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,322
