Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Vragen Bekijk alle
black screen - wont restore
Hi
this is my first post on here, but been using ifixit for a while now.
i have an iPhone 5c.
Its screen is almost constantly black and won't come on. I've tried hard reset and it seems to switch on and off whilst doing this. (you can here the ping as its recognized with USB attached). The phone does not vibrate or light up when this happens.
When i connect to iTunes, it says it detects a phone in recovery mode. So i click to update. Itunes starts doing its thing, extarcting, preparing iphone etc, the screen then comes on with the apple logo and a progress bar. But iTunes then just says 'waiting for iphone' i have left it for some time and nothing happens.
Any advice would be greatly appreciated
Dan
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Tried a force restart? If so, do you get an error code, after restoring the phone?
How to Force Restart an iPhone 5
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Tried that. It doesn't restore, so no error code. Just keeps saying waiting for iphone
door
Tried disconnecting and reconnecting the battery?
iPhone 5c Battery Replacement
door
Yes, now tried different screen, different battery, I've also disconnected the camera/proximity sensor connection, still the same
door
I have the exact problem,did you ever figure out a solution?
door
Sounds to me the LCD may be defective or broken. Try replacing the screen with a good working LCD/Digitizer and see what happens.
3 opmerkingen:
Thanks for your reply
The screen works during the restore, it's just not working at any other time. Could this still be the the screen that's causing this?
door
Does it keep repeatedly make the ping sounds when it's plugged in? Can be caused by a screen going faulty too.
door
No. Pings a couple of times at certain parts of the update, but then just sticks, with the apple logo and a progress bar on the screen
door
Voeg je antwoord toe
Dan Hurst zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 331
