Ga door naar hoofdinhoud
16:9 LCD monitor with a 1600x900 resolution display.
I can barely see the screen
I can barely see the screen and adjusting it makes no difference
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
shawn sounds like your backlight has failed. Most common cause for that are bad capacitors. Your monitor does not have a separate inverter but it is part of the power board. Start by disassembling the monitor and take a look at the boards and the caps. Check for bulging or leaking caps. Post some good images of your boards with your original question. For that use this guide. Since I only have the assembly instructions, substitute the assemble with disassemble
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
I went ahead and tore it apart right after posting the question and not one of the caps had much for capacitance,they was toast.
door
Did you replace those?
door
Voeg je antwoord toe
shawn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 33
Altijd: 773
