Wont stay running for more then 20 seconds
Mower wont run for more the 20 seconds no matter what i changed new plug,starter,clyinoid,and new kill switch any ideas
Is dit een goede vraag?
tony alexander, Possibly easy fix. Before applying oldturkey's good suggestions, remove the gas cap and see if engine runs better/longer. If it does this signifies a plugged gas cap vent and is quite common. Dirt and dust can accumulate and eventually plug the vent hole in cap which will restrict fuel flow and can cause engine to quit.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Was dit antwoord nuttig?
I was ready to pull everything apart to fix and fortunately saw this suggestion. Worked!
I was going crazy....Toro Recycler 22 with Kohler engine...start, then stop. Cleaned everything, new filters, new spark plug, nothing worked. Put a few ounces of Seafoam in the tank with new gas, sprayed some Seafoam into the carb, and magic....had the same problem with a Ryobi string trimmer, and magic again. Wish I had found this post earlier and saved a lot of time and money! THANK YOU JIM!
tony alexander this sounds more like a fuel delivery issue. So I'd focus on the carburetor i.e. stuck float or needle valve as well as checking the intake and exhaust valves. The ZTS7500 comes with Kohler as well as Briggs and Stratton engines (should be a 44P777-0130-P1 or 44P777-0130). The Intek™ OHV V-twin utilizes a fixed jet, two barrel, side draft, flo-jet carburetor. Except for idle speed, the carburetor is non-adjustable. The carburetor incorporates a fuel shut off solenoid which controls fuel flow to the fuel metering system. The solenoid is controlled by the ignition switch. Try and see if you can give us your engine make and model so we can get more information about the fuel system.
is a typical diagram for a B&S 44P700 engine carburetor #133 shows the float
Can the fuel shut off solenoid be replaced on a 15.5 ohv briggs
Before you disassemble anything, try this -- it worked for me.
Buy a can of Seafoam gas treatment (https://seafoamsales.com/small-engines/), put some in an empty gas can, and fill the can with new gas. Drain the gas from your tank. Swish the gas can to mix the seafoam and the gas, and fill the tank with the seafoam/gas mixture. Now start your engine.
After I did this, my lawn mower ran like new. It still is, months later.
Winner winner chicken dinner. Toro with 6.5 b&s engine would start up 1st pull and stop 3 sec later.
Read jim phelps answer and it sounded good to me.
I had startron small engine fuel treatment handy. Pored about half an once into empty tank then about an ounce of gas. It did the start stop thing about 4 or 5 times but noticed the run time getting longer. Once st struggled running for a minute or 2 it got smoother. Filled the tank and let run for 5 min. Smooth going.
Then i cut grass.
Thanks Jim!
Glad you got it fixed without having to disassemble anything.
Seafoam is a miracle cure for clogged fuel systems. If you ever can't get the system unclogged with some other product, try Seafoam.
The symptoms described is a signature issue on this type Briggs 6.5 Carb (and others that use it)
If any debris gets in the fuel and fits thru the float valve it settles at the high speed jet that is at the bottom of the fuel bowl. In fact it is the brass piece that holds on the fuel bowl to the carb.
I find it best if it comes down to having to fiddle with this jet, to remove the carb, get some Lacquer thinner and a small brush and thin wire and really clean clean clean all dirt off the outside. Then throw that Lacquer thinner away, clean the container and take the hi speed jet screw out of the fuel bowl. If you are careful and gently pull things apart, hopefully you can save the rubber gasket between the bowl and carb. If it sticks, wd40 it with spray and keep working it off.
Next, Ya gotta have some air pressure to blow out the carb, and you first should let it soak for a while. Take the float off and shake it to make sure there is no fuel in it. If it is leaking and I have never found a plastic float that leaks, it will have to be replaced.
Once the carb has soaked, wire out all the holes and then soak again and wire again, and then blow out every hole you see. Make sure to put the air tight against the float valve hole.
Reassemble, the reverse of taking it apart, reinstall, and next, Clean the filter with air and clean the filter holder with the left over carb Lacquer thinner, so that you are starting out clean.
And don't take any short cuts trying to prime and start the engine without reassembling everything. All the parts including the filter are required to be installed to get the silly thing to run.
Prime it with the prime bulb and pull away!
There is another possibility that hasn’t been mentioned- water in the bottom of the fuel tankf. If just the right amount of water gets into the tank, it will allow a mixture of fuel and water to get into the carburetor. And you get the same symptoms. After trying several times to start the engine *some* fuel will make it into the engine from all the shaking as you pull the starter cord. It can be enough to start, and run for a few seconds before more water is pulled into the carburetor and the engine stalls again.
Solution- disconnect the fuel line from the carburetor and let the fuel drain into a clear container. You will see the water in its own layer at the bottom of the container. Don’t forget to drain the fuel bowl on the carburetor also.
Thanks Lance! Wish I had found this two weeks ago! After trying everything and still no go(literally except for about 6 or 7 seconds) I ordered an new carburetor and it arrived today. Out of curiosity, before replacing the carb,, I tried your solution and it worked. I knew I had gotten water in the fuel but I thought I had gotten everything out, I can however return the carb to Amazon with free shipping but I can't get my time back that I spent my recently retired days on this JD lawn tractor :-) Thanks for taking the time to post here!
Afgelopen 24 uren: 41
Afgelopen 7 dagen: 315
Afgelopen 30 dagen: 1,089
Altijd: 139,824
5 opmerkingen
Sounds like a fuel issue. Does your mower restart immediately after it stalls? For those 20 seconds the engine actually runs or is it stalling etc.? I'd start with considering a stuck float.
door oldturkey03
I had the same problem. Stripped the carb down and found the float bowl was full of waxy beads like wet silica gel which was jamming the float. Cleaned it out, blew through the jets with compressed air, put it all back together and now it runs better than it has for ages.
door philipfraserbrenchley
My mower dies if I try to Throttle it up have changed fuel filter and plugs
door Ryan Robison
I have replaced my carburetor and spark plug and it has new gas in it does not stay running
door dustin25steffen
10 sec run and then dies. take off the muffler and see if it runs. dirt dobbers can clog up the muffler. ask me how I know this
door JP2wrench
