Ga door naar hoofdinhoud
De MiP robot werd uitgebracht in augustus 2014. MiP is een interactieve robotspeelgoed ontworpen voor kinderen. De robot reageert met behulp van handsensortechnologie, evenals een downloadbare app waarmee MiP kan rijden, dansen en spelletjes kan spelen.
MiP Rechargable battery kit
Hi,
I have a MiP and I am currently using 4 x AAA 1.5 V Alkaline batteries. This provides 6 V to the MiP.
I am thinking of buying a MiP Recharge Kit(http://store.wowwee.com/mip-robot/mip-re...). I heard that the Kit consists of LiPos and that it would make MiP slower/less responsive. Is that true?
What is the voltage supplied by the Kit? Is it less than 6 V?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Contact the seller to ask what the battery output voltage is. It should be 6V. Anything less would impair the operation of your MiP. Given that it is being sold as a replacement unit to use instead of AAA batteries, it should be supplying the correct output. It never hurts to ask though.
The other thing to find out is the capacity in mAH of the LiPO battery.
Standard 1.5V AAA alkaline batteries can vary between 400mAH - 900mAH, depending on what capacity the manufacturer has decided to make. Their life span then depends on the load that they have to supply. Obviously the higher the battery load to less time they last. Also the more that they are used the less time they last.
Obviously if the LiPO battery has a greater capacity it will last longer. LiPOs also maintain their voltage well as they discharge so that should not be a problem.
This link may be of interest to you.
http://www.rogershobbycenter.com/lipogui...
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
sabbu92 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 1,724
