Ga door naar hoofdinhoud
The Samsung HLM or HLN series is a line of projection televisions.
20 Vragen Bekijk alle
Why is the lamp display flashing on my power button?
I purchased a replacement lamp off amazon for the make and model of my Samsung TV ( hlp5063wx/xaa). Received the replacement and it still doesn't turn on, with the lamp display flashing on the power button. Any ideas as to Whatelse could be wrong?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@zanzel4 could be power board or ballast issue. Make sure that the lamp door is properly replaced. There is a lamp enclosure cover sensor, if the sensor is not depressed all the way, your set thinks the cover is missing and you will get the lamp error code as well. Once you get it back on try see if this works for your set:
After completing the lamp replacement, enter the Service Mode
Press the remote control Keys in the following sequence:
“Power off ➔ Mute ➔ 1 ➔ 8 ➔ 2 ➔ Power On”
The Service Mode Screen appears in 15 ~ 30 seconds.
(1) Select 7(OPTION) with using the joystick downward, and then select the LAMP CLEAR with using the joystick in the displayed menu.
(2) Press the + key to select LAMPCLEAR OFF.
(3) Press the + key, LAMPCLEAR CLEAR is displayed in the screen.
(4) Exit factory mode.
If it does not, post some images with your original question (use this guide) of your boards and what your set looks like since there are different ways of testing the boards etc. Of course the set worked before you replaced the lamp?
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thanks so much! I'm going to run through and try all that now, I don't have the remote for the TV, only a universal, would that matter when trying to enter the service mode?
door
The universal remote might work, give it a try and see what you get. Let us know.
door
Voeg je antwoord toe
Zack anzel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 905
