Ga door naar hoofdinhoud
Location of power pads
Macbook air with liquid damage, did a board cleaning and device powered back on. Now a couple month later it doesn't power up.
While trying to reset smc I notice there are no change to the charger indicator light. I suspect the power button has failed. I'm looking to jumpstart the macbook air to validate that, and if so, change the keyboard assembly.
I know Macboks usually have a couple power pads that can be bridged to power it up.
Does anyone know where they are?
thanks
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Emmanuel Marti check the attached image for location.
Afbeelding
Was dit antwoord nuttig?
Score 10
7 opmerkingen:
Hi!
I have the same problem. I have now located the "debug power button". But does not work to press on them. How do you do it? And why did you put a red circle around the black thing?
door
knutegil11 the red circle is from another guide where this image comes from. disregard it. you will need a flat head screwdriver or a paperclip to "bridge" the two contacts in the blue circle. If that does not work, then you are having plenty of other issues with your board.
door
Ok, then I guess my Mac is broken for sure... Thank you for answering :)
door
Before you get rid of it, track another ultrasonic cleaning with some Branson ec.
door
@gigabit87898 why? knutegil11 did not mention anything about water damage or any other damage.
door
2 commentaren meer tonen
Voeg je antwoord toe
Emmanuel Marti zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 66
Altijd: 25,660
