Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Alcatel One Touch Idol 3 heeft een 5,5-inch display van 1080 x 1920 pixels, aangedreven door een 1,5 GHz processor. Uitgebracht in juni 2015. Modellen 6045Y, 6045K, 6045O, 6045I.
My Powerbutton don't work anymore?!
My Phone was always covered by a Flipcase, yesterday i took it out cause the Powerbutton did not react.
But now it dont work anymore. At first it worked after 10 times pushing, but now i have to wait for any message, that the display come out oft "sleep" mode...
what can i do ?? i dont know if i can fix it alone :(
i dont want to loose this phone, its really New... Please help me.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Filteren op:
the power button on the idol 3 can be finicky as they are prone to failing. they ARE soldered to the circuit board so I would advise finding a local electronics repair shop or good friend with minimal soldering experience- seeing as the actual replacement is as simple a solder job as one could imagine . the component replacement, itself, is about $8.00 online.
http://www.ebay.com/itm/Alcatel-One-Touc...
Was dit antwoord nuttig?
I was having the same issue for almost a week now. My phone is visibly in great condition (screen in tack, no cracks or scratches, etc.), but the power button just gave out on me. The only time I was able to use it was if I plugged it into the battery.
Finally, i decided to download an app by searching "Power Button to Volume Button," and voilĂ  it works. I now use my up or down volume to turn my phone on! I hope this helps you, too.
Voeg je antwoord toe
Christine zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 1,484
