Ga door naar hoofdinhoud
Uitgebracht in Japan op 12 december 2004, in Noord-Amerika op 24 maart 2005 en in Europa op 1 september 2005.
Number of problems with my PSP 1000.
Here's the deal: a friend of mine was just going to toss out his PSP, but I convinced him to let me tinker with it, to see if I could fix it.
The battery has difficulty holding a charge.
The nub/joystick is non responsive and has sporadic movements.
The D-pad seems to want to gravitate the curser down and right.
Any suggestions on how I can fix these issues? Or is the system too far gone?
Is dit een goede vraag?
Score 3
1 Opmerking
why my psp is slow when playing video
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You might be able to solve the D-Pad issue with the PSP Button Guide.
It is a really old hand console, so the battery should be dying by now. Unless you found another battery, it'll need to be cabled to the wall.
Maybe try dusting out the joystick when you go in to clean up the D-pad buttons and see if that works?
Was dit antwoord nuttig?
Score 6
man your psp is awsome its almost like new all you have to do is open your psp and take out the joystick (but remove the round top before opening it) and take out the small black piece thats under the round top
then place it properly back into its place
Score 1
I can do 2 for you
PSP 1000 Knoppen Afbeelding
Handleiding
PSP 1000 knoppen vervangen
Moeilijkheid:
Eenvoudig
15 minutes
PSP 1000 Batterij Afbeelding
Handleiding
PSP 1000 Batterijvervanging
Moeilijkheid:
Eenvoudig
1 - 3 minutes
4 opmerkingen:
yeah, but you are almost a year to late ;-) and its the same answer.
door
there is no late or early
door
but it's the same answer as above, so you have not given anything new...
door
well 1 thing.the battery
door
Voeg je antwoord toe
Colin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 8,429
