Ga door naar hoofdinhoud
Coffee brewmaster released in 2013. The Keurig K40 is a k-cup compatible coffee maker.
31 Vragen Bekijk alle
Why am I not getting a full cup of coffee?
I have been pressing the large coffee option, but when the coffee is done brewing my cup is less than halfway filled!
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Check to see if your k-cup is seated correctly in the chamber. It may just be out of position and the needle located where the k-cup is placed is not puncturing the device properly.
The needle of your Keurig may also be clogged with coffee grinds and gunk, you should clean it off with a cotton swab if the problem persists.
Check out this troubleshooting guide if you need more assistance.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
@abornemann what needle? Where is it located? How do I clean those? Why would a clogged needle cause this?
door
Het nuttigste antwoord
@rosiecheeksxoxo I do realize that this is an assignment but if your Keurig would really have those symptoms, follow this guide to show you what and how to clean. Slightly different model, same principle.
Score 4
My coffee not coming out at all it's just clicking
Voeg je antwoord toe
Michelle Sanchez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 1,207
