How do I wire a tachometer
how do i wire a tachometer on a 1993 jeep grand cherokee
Is dit een goede vraag?
jimmiller1940, as a general answer since we do not know which tach you have, most aftermarket tachometers only have 3 or 4 wires that need to be connected. Usually a green wire for the tach, red for power, black for ground, and white or yellow for the back light. The power wire that gets connected to a 12 volt ignition source, the tach signal wire that connects to the coil or the designated signal wire in your cars wiring diagram.
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 949
1 Opmerking
what make and model is your Tach? Post some images of the connectors with your question. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that
door oldturkey03
