Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Dell Precision M4600, een laptop van 15,6 inch die deel uitmaakt van de Dell Mobile Workstations met sterke verwerkingscapaciteiten, werd tussen 2011 en 2013 uitgebracht door Dell.
Screen Flickering when start from Cold
My Laptop Screen flickers with fuzzy pixels when it start from cold and still flickering until it warm up then i should close the lid and open it again to disappear and back to normal state.i attached external monitor to check if this from graphics card but external monitor worked fine without any problem.i want to know if this problem from the screen itself or problem with the motherboard?
this video show how it`s flickering.it`s not my laptop but just for clairfying the problem.
https://www.youtube.com/watch?v=ctHn8P-2...
Thanks in Advance.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
hi ,
I disabled optimus nvidia option from bios and this solved my problem.thanks for your help :)
Was dit antwoord nuttig?
Het nuttigste antwoord
mahmoud eldeep since it displays properly on an external monitor, I'd exclude the motherboard/GPU. It is easily possible that you are having issues with the LCD. I'd start there.
Score 2
9 opmerkingen:
Thanks for your fast reply. but is there any explanation for this phenom? is cold can effect on the screen and make it flickering like this?
door Deel
Yes it can. coils,caps and resistor as well as transformers can have cold solder joints that may close during warm up.
door Deel
I`ll replace my screen and feed you back with the results. Thanks Man
door Deel
I have another Dell Latitude E5520 with Screen of 15.6” HD (1366x768) Anti-Glare LED. I exchanged the two LCD and my screen works fine till now on latitude without any flickering from startup and latitude screen works fine too on my laptop without flickering at startup too till now.my screen is 15.6" 1920x1080 HD Ultra Sharp Anti-Glare LED.what may cause this problem??!
door Deel
the problem not from the monitor as i replaced it with another low resolution one (1366*768) and it did not show up the problem.i think it`s something related to power input from graphics card to the monitor as FHD monitor consumes alot of power than the HD monitors.but i still can`t determine which part i should replace.
door Deel
4 commentaren meer tonen
https://okadtech.com/dell-laptop-screen-...
Hope this will help you
Voeg je antwoord toe
mahmoud eldeep zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 42
Altijd: 9,355
