no picture no sound
32 days after I bought this tv it went out. no picture or sound. I had it repaired under factory warranty. 2 years later, it happened again. the same exact thing. I put it in the closet and went and bought a new t.v. The other day, I pull it out of the closet to see if I could repair it. After exploring the web, I ordered a new "A" board. I changed it out and now my back lights come on but nothing else. What else could be causing my problem?
Is dit een goede vraag?
Sony TV sets will sometimes generate error codes after you turn on the TV set, and it fails...Do you see a series of blinks occur then a pause, then the same blinks, then a pause over and over on the LED power lamp?
If so, count the blinks and let me know how many blinks between pauses?
If the TV just turns off and NO BLINKS, let me know that too.
Also, the MODEL number located on the right side or the left side tag is important.
If you do not find the tag on the left or right side, then look on the back for the model.
It could be a KDF52xxx or a KDL 46xxx or a KDP 40xxx type of Model, but they always start with the letter K in the model.
door Matt Zieminski
model# KDL40S4100 . No blinking led, just solid green.
door David Merritt
I have one too that was given to me to fix. When you turn it on you can here the normal click and power up sound and power button lights up green and it stays on with no blinking but the screen doesn't light up and no sound. All it show is the little lite up green light. By; Jason
door Jason Pust
How much is a (A) board?
door Jason Pust
@pust76 A-board for what model?
door oldturkey03
5 commentaren meer tonen
