Ga door naar hoofdinhoud
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Vragen Bekijk alle
Vraag afgerond
Fan spinning without stopping and not detecting any hard drives
Hello, so I decided to clean and change the thermal paste on my macbook pro, and after the deed, I put it all back together. Now, when it starts, the fan spins at maximum capacity all the time, and my hard drive isn't detected. I've launched ASD and it tells me the only problem with it is the fan motor, since it can't regulate it, but other than that every sensor is in good shape. Thanks for any help you could give me, it's probably a really dumb solution, but it's the first time I've done this !
Is dit een goede vraag?
1 Opmerking
Why did you replace the thermal paste? Were you getting a lot of beachballs?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Review the IFIXIT guide: MacBook Pro 13" Unibody Mid 2010 Fan Replacement Step 4 (all three images) compare your connectors are they damaged?
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
I've looked and I can't find anything wrong with them, everything looks fine !
door
Then you have a deeper problem here than just the fan. I would suspect you'll need to take the system appear again and review the IFIXIT guide steps to locate what you did wrong. Here's the IFIXIT guide you should review: MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement
door
But what should I review? I don't think I did anything wrong, but just in case, if I put thermal paste but chose to use the heatsink to spread it and not do it myself, could it pose a problem?
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 53
