Ga door naar hoofdinhoud
De Samsung Galaxy Grand Neo werd in februari 2014 uitgebracht. Het is een mid-range smartphone met een 5,01-inch digitaal scherm en een variant met dubbele simkaart. Het model GT-I9060I staat bekend als de Samsung Galaxy Grand Neo Plus.
Falling in the water
Hello everyone.
Two days ago my phone falls in the water. I tried to dry it up with hair dryer and also i left it for two night in a dry place.
Yesterday it works and when I turn on my mobile, it displayed a notification that is enabled the safe function. Το disable this function click here and the device will be restarted. After this all the applications will be available. When the device restarted it displayed the same. Also when I charge the device with or without battery the flash turns on. Is there anybody who can help me to solve these problems.
Thank you very much.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
bellonig23 the issue here is that you will need to clean your phone. For as long as you have not cleaned it, you are running risk of shortening out your phone even further and causing increased damage. I would suggest that for the time being you do not try to charge it, or to turn it on. Disassemble it using this video. Then clean it properly with isopropyl alcohol. Use this guide to see how to clean it. It was written for an iPhone but all the points are still pertinent to your phone as well. Once you have it cleaned properly, you must replace the battery. then reassemble and re-evaluate for residual damage.
Was dit antwoord nuttig?
Did it work.
Mine's victim to Burmese water festival.
Grrr...!
Voeg je antwoord toe
bellonig23 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 974
