Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Uitgebracht in mei 2004. Te herkennen aan het modelnummer T42 van de ThinkPad T40-serie.
Will not switch on?
No charge lamp lit prior to switch on. No lamps illuminate, no noise, nothing happens when "on" switch depressed. Same occurs with battery removed and ac supply (which is correct) is plugged in. This looks pretty terminal yes? Grateful for any advice, thanks.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
I don't think I would say terminal yet. I am including a link for the service manual for your computer--maybe it will show you a way to save it. Ralph
http://download.lenovo.com/ibmdl/pub/pc/...
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thanks Ralph, I've checked out the link, followed the procedures and looks like the system board is defective. I've found a refurbished board on e-bay at £40 so it's decision time. I have an electrical background but I've never dismatled and fitted a laptop motherboard. The step by step guide from this site makes it sound doable providing I take care and take the precautions listed in the link. I think it might be worth seeing if I can remove the old one 1st. What do you think? Thanks again, Mark.
door Deel
door Deel
+. I say go for it Mark, what do u have to lose?
door Deel
Certainly try the removal of the faulty board first---just be sure to identify and save the hardware. Good luck Ralph
door Deel
Check the status of the internal button BIOS battery. Also make sure that at least the power light is on when the power adapter is plugged in.
Voeg je antwoord toe
mark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 1,800
