Ga door naar hoofdinhoud
Reparatiehandleidingen voor moederborden en CPUs.
Where to buy replacement CPU socket?
Greetings,
Where can I buy a replacement CPU socket? I have searched and searched and only been able to find one store on eBay in China. Anyone know a place in the US?
www.ebay.com/itm/Original-New-Foxconn-H2-Socket-LGA1155-CPU-Base-PC-Connector-BGA-Base-/231098753262
Thanks
Is dit een goede vraag?
Score 2
4 opmerkingen
"Charles, if you can find one, how would you solder the hundred + connections?"
You do not solder. You heat the socket with heat gun to melt solder balls.
door
Would be better to buy another motherboard.
door
Im bga certified, I just need the part
door
EBay and how much to fix my motherboard same problem jandersen
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Charles all searches came up Shipping from China/Hong Kong/Taiwan to worldwide (7 to 19 business days) for the replacement CPU socket Foxconn-H2-Socket-LGA1155-CPU-Base-PC-Connector-BGA-Base-/231098753262. It may be worth trying to place the order on Ebay for the price of part $3.59 and shipping $3.30.
Good luck with the part and installation.
http://www.ebay.com/itm/Original-New-Fox...
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
Score 2
4 opmerkingen:
They come with solder on the grid. You use heat gun.
door
Or you can BGA Reflow them if you have the balls and stencil
door
You just added a clean socket. No solder on it to reflow.
door
@mayer sounds like robert is referring to a reball. Solder balls and stencil combined with a rework station can accomplish this task.
door
Voeg je antwoord toe
Charles Kensington zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 8,564
