Ga door naar hoofdinhoud
Model A1311 / eind 2009 / 3,06 of 3,33 GHz Core 2 Duo-processor
iMac 21.5 late 2009 no power up
Hello. After having pulled out hair dryer from the electrical outlet my iMac has stopped working. the power supply and the fan was working but the screen was black. I turn it off with the power button and then power it on again but it does nothing. . Only Led 1 is on on the logic board.. with a new power supply again the same. We measure everything in the logic board(with schematic) and all it's ok. What else must do?
Thank you
Is dit een goede vraag?
Score 5
3 opmerkingen
Could you solve it?
door
It's still the power supply.
door
Yup! That it is.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@tano32 - Agustin, Sadly this one slid by us back when it was posted. I hope Dimitris got his system running again.
What likely happened is when the hair dryer was pulled out of the outlet still running it created a power surge which caused the iMac's power supply to fail. This is why we strongly recommend using a good surge suppressor to protect from such events. It could have been a lightning storm or other event along the power line that could do you in. In some places the power is very dirty! In fact here where I live in the city our lights constantly flicker (LED lights more so) as it's so bad. We use UPS's as surge suppressors wear out from it being so bad. And we have a building suppressor added as well to the buildings fuse panel.
So getting back to what the symptoms are telling us here is the diagnostic LED (LED#1 on) the power supply is damaged and needs to be replace. Here's the IFIXIT guide you'll need to follow: iMac Intel 21.5" EMC 2308 Power Supply Replacement.
For reference here's what the diagnostic LED's tell you: iMac Intel 24" EMC 2134 and 2211 Diagnostic LED's Apple still uses them in there iMac's so don't be concerned on the fact this is not the same model as your's. Jump to Step7 for the writeup on the LED's.
iMac Intel 21.5" EMC 2308 Voeding Afbeelding
Handleiding
iMac Intel 21.5" EMC 2308 voeding vervangen
Moeilijkheid:
Gemiddeld
30 - 45 minutes
iMac Intel 24" EMC 2134 and 2211 Afbeelding
Handleiding
iMac Intel 24" EMC 2134 en 2211 diagnostische LED's
Moeilijkheid:
Gemiddeld
15 minutes
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
can you adapt an atx font to do a test? Does anyone have connections and voltages?
door
Sorry, you'll need to get the Apple power supply its not the same size. Here's the part you'll need: PowerBookMedic - iMac Intel 21.5" Power Supply - Apple P/N 661-5299
door
Voeg je antwoord toe
Dimitris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 1,681
