Ga door naar hoofdinhoud
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
198 Vragen Bekijk alle
IC problem..how much is the cost to repair it
IC problem cant charge,cant power on
Is dit een goede vraag?
Score 4
5 opmerkingen
Just it fallen down bt its nt swtchng on i askd my friend he said it cant repaired if mobile falls vl it b dead
door
my Samsung note 4 gallery you tube camera vediou stop after a few seconds what is the solution please help me.thanks imtiaz
door
i also clear data every thing you tube gallery you tube camera but my vedioues in all applications stop after a few seconds.please help me.
regards imtiaz
door
I have a galaxy 8plus .How much will it cost me to get the power ic fix?
door
I c problim and no signal
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
actuallydrug228 not sure how you know for sure it is an IC issue. You did not tell us if you checked the battery, the charging port and even the charging cable. If you are 100% certain it is the power management IC, then you have to find a place that does those repairs. It is a BGA chip and not easy to replace. As for cost, ifixit does not do repairs. For that you will have to try and find someone in your geographic location that has the knowledge and the tools to replace it.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Yeah im jst askng u sugesstion vl it get repaird i askd in repair center he said ic hd gne cant switch on mobile is dead
door
It cost me MYR 350 for Samsung S7 Edge
Score 1
RM180 for me for Xiaomi Mi Mix 2. With 3 month warranty by SPR in Kepong.
Score 1
Voeg je antwoord toe
actuallydrug228 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 171
Altijd: 21,204
